correct taper
Trevor
Hi Kevin I have a 2000 Legend 340 with a yanmar 3GM30 the boat is in UK although she was built in the states. I am hoping to change my two blade prop to a fixed 3 blade prop, can you confirm the following for me that the American shaft taper is 16 to 1 on a 1 inch shaft. British is 12 to 1 and metric is 10 to 1 on 25 mm I believe
P
Pete
Trevor/340 prop
Trevor,curious as to what size and make 3 blade prop you are switching to? Thanks Pete
K
Kevin
,SAE taper
Hello Trevor, The SAE taper, as it is called in the US, is a 1:16 taper. If your machine shop or propeller shop does not have the dimensions we could fax a sheet to you outlining the needed measurements. Take care. Kevin
Trevor
correct taper - prop size
Hi Pete I am changing to a 16 x 12 3 blade prop, at present I have a 16 x 13 two blade. Not sure of make I will be getting it from a firm in Poole in UK, cost £190, I bet it would be cheaper for you in the US ! Trevor
Trevor
Kevin Thank you for your kind offer to send a fax sheet with taper dimentions , My machine shop now has a piece of legend 1 inch shaft with correct taper regards Trevor
