For Inverters
There are "Modified Sine Wave" and "True Sine Wave" inverters as you are aware of. A modified sine wave inverter is generally more suited for appliances such as air conditioners, heaters, power tools like sanders and drills and saws, air compressors and the like.
Sensitive electronic equipment like computers, expensive TV's and the like seem to want more stabilized power supplies without the voltage fluctuations and surges normally associated with some of the modified sine wave inverters.
I'm sure you can guess the cost difference between the two. I have a modified wave inverter and have not used it for my laptop or TVs since I have 12 volt supplies available for them and that is their requirement.
I'd try to stick with a 12 VDC set up since it is a lot cheaper than an inverter.
Maine Sail, I'm like you, a big fan of the iGo device. I have a variety of adapters and invariably will have someone on board that forgot their charger for their cell phone and low and behold, I have an adapter that will fit their phone 8 out of 10 times. I love that little gadget
