G
Greg Sampson
Just went in the water yesterday and I have two leaks, the drive shaft stuffing box has a drop every 5-7 seconds at the nut, and the rudder stuffing box is a little quicker. I know that the drive shaft should drip, but isn't it only when the shaft is spinning? and how do I tighten it(which side of the nut) so that I know it is not too tight. and on the rudder side, does that nut (looks similar to drive shaft nut) perform the same function? that is wher it looks like the drip is starting from...in between the nut. thanks,greg
