Battery Charge
While I agree with Don that voltage may not be the best measure of the condition of your batteries, it does tell you something important. I have a chart that indicates that your batteries ought to show 12.6 - 12.8v to be fully charged and that batteries showing about 12.23v are less than 50 per cent charged -- a seriously deficient condition. First thing to check is the device you are measuring the voltage with. Some of the cheap digital VOMs on the market can be off by a lot. Another thing to check is the output of your alternator, which ought be putting out over 14 volts when the engine is running. Anything less is not charging your batteries.
