Correct Battery Size
Jerry B
Multiple questions - Suggestions would be greatly appreciated..... (Lauching next week)! Just purchased an '89 272-LE. Not sure which size battery is required. I have been told by salesmen at the local marine supply stores, that the group 24 size is adequate for this boat. Which is what the previous owner left behind. However, he had two battery boxes that are the group 27 (larger) size. 1- What would you recommend? (We will cove out on it most weekends, using lights, stereo, pressure water/heater, occasionally use radar.) 2. Will standard dual purpose batteries such as the Sears Diehard Deep Cell's be sufficient? Or will I really need a dedicated starting battery for the Universal 10hp diesel? 3. There is a "battery shelf" up high in the quarter berth. Is this the standard place for it? Thanx in advance Jerry B.
Don Evans
Bigger is Better in Batteries
Jerry for the power requirements you have listed, I would get the biggest battery you can afford. Add up all your electronics amperage needs and multiply by the # of hours on the hook then double that A/H answer by 2, so that you don't go below 50% of your battery rating when the batts run down. I would also get a "matched" 3 stage charger. Assuming you can plug in at your slip, wire the charger into your boat electrical system. If you are out on the hook and want to replace a few amp hours get one or 2 good size solar panels. That plus what ever you can get out of your alternator will prolong your electrical bank. I would also recommend a battery moniter to guage your voltage, charging current and amp hours consumed. Takes the guess work out of it. I would have a dedicated starting batt. Does not have to be a brute , just a smallish car battery should suffice. Keep it seperate from your house bank, using a switch, or isolator. I have 2 6V 220 amp/hr golf cart batts, and a guest 10A 3 stage 2 bank charger. A cheap car starter batt, a 1-2-both-off switch, and a Trace battery moniter. Two 2 amp solar panels, and an alternator on the diesel round out my charging capabilities. Its taken a few years to assemble my system, but I finally feel I can just about meet my electrical needs. The only thing I would change would be to increase my solar panels to 2 5 A panels. Its a work in progress. I would mount this mass of lead as low as possible, to add to the stability of the boat. Also should be readily accessible. There is a lot of opinion on battery type (gell, AGM, wet), make (dual purpose, deep cycle, 6 V, 12 V). Check out the books in this forum, under electrical. Sorry for the rambling, but this is not a simple subject. Good luck with your decisions. Don
Justin - O'day Owners' Web
Link 10/20
Jerry - Not much to add to Don's post - there is never much to add to Don's posts - but I would make one specific recommendation. The Link 10 (or for multiple banks 20) is a great device that keeps track of amp hours in and amp hours out so that you know exctly how much juice you have at any moment. They're a couple of hundred bucks, but worth their weight in gold on the hook. Justin - O'day Owners' Web
