"Coring" line advice
241
Catalina 30 MkII Foss Harbor Marina, Tacoma, WA
Good morning everyone,
I'm replacing my furler line and in order to get more space on the drum I've decided to remove 20' of core from the 60' 5/16" line as recommended by Hood. My question is should the cover be simply slid back on the core (this became difficult on a test piece of line as it soon bunched up), or should the cover be turned inside-out and pulled, similar I guess to removing a sock? The West Marine rigging shop wants a week to do it.
I'd appreciate any advice...
Thanks
Tim R.
May 27, 2004
3,626
Why no open up the braid where you want to cut the core and then pull it out? A good fiddle or marlinspike should allow you to pull out a loop through the braid once opened up.
xcyz
Hunter 376
Doing this I think is a great idea but I haven't done it myself. I just went to my stash of extra lines at home and tried to open the line and remove the core and found it difficult at best. It seemed to not only pull the core but the casing as well. I then tried the other method by pulling the casing over itself as you described and it was much easier. I think the line material will have a lot to do with the method one is successful with.
May 24, 2004
470
Hunter 33.5 Portsmouth, RI
Why not use a slightly smaller braided line, or re-estimate the length that you actually need on the drum? Most drums end up with too much line on them when the jib is out. Check the drum to see how much line is remaining on the drum when jib is fully furled?
Dec 2, 1999
15,184
That makes more sense to me too.
Oct 2, 2006
1,517
Jboat J24 commack
On my 29' with a Profurl all i can fit is 1/4 " and with a 2500# rating for basic line it is plenty strong
IF you pull the core or cover you would drop well below this # anyway
RichH
Feb 14, 2005
4,773
Tim's advice is the probable best recommendation. Remove the core where the line wont be touched with your hands, this will leave a 'fatter' rope in the section where your hands do hold/pull the rope. A 'fatter' rope will have less potential to injure your hands, especially good when you have to furl/reef in high winds; imagine pulling on that line in those conditions ... with a 'string'. A 'de-cored' line will also have less potential to jam or 'overlap' inside the furling drum because it rolls-up 'tighter'.
Another tip for 'safer' roller reefing is to use a harken 'hexaratchet' to control the furling line as it pays-out when unfurling when the jib/genoa is under load. A hexaratchet applies friction as the line pays out - the amount of friction is determined by how much pressure you use to 'tail' the line as it pays out, no friction as you 'pull in' the line. http://www.harkenstore.com/uniface....?CATALOG=409Z56LC7FV66&CATEGORY=409Z56LC5373M
Apr 1, 2004
185
Catalina 34 Herring Bay Chesapeake, MD
Thanks
Fox,
I just installed an Hood 808 furler. 20' from the end of the double braid I bent the line in half and slightly bunched the cord. This allowed me to seperate the strands of the outer core and pull out the inner core, which I then cut off.
Mar 26, 2011
3,968
Corsair F-24 MK I Deale, MD
Two things:
1. It's Flat. A de-cored rope (cover only) set flatter on the drum and can give better reefing performance (less shifting). Furling it makes less difference.
2. New vs. Old Rope. Splicing or de-coring old rope is MUCH more difficult than with new rope. I doubt you will have difficulty with new rope. If you MUST spile old rope, gently working in some fabric softener helps, but it may still be very tough.
Joe
Jun 1, 2004
8,323
Don't milk the cover back to remove the core.... bend the line where you want to cut, dig the core out with an awl or ice pick and remove the part you want to discard.... cut with hot knife, or cut and seal the remaining end with a small torch so it won't unravel.... pull the cover back over the core.... LOCK stitch the remaining core inside the cover....at least 5 or 6 pairs of stiches at right angles to each other... then seal the remaining cover only end with a hot knife or small torch.
Jul 1, 2009
221
Catalina 310 Sydney-Pittwater
RichH
"Another tip for 'safer' roller reefing is to use a harken 'hexaratchet' to control the furling line as it pays-out when unfurling when the jib/genoa is under load. A hexaratchet applies friction as the line pays out - the amount of friction is determined by how much pressure you use to 'tail' the line as it pays out, no friction as you 'pull in' the line."
Would these blocks, in your opinion, also assist with furling? Either single or in tandem? About 2 years ago I got 2 fingers on each hand caught in a mooring line in high winds and cracked 3 of them. I recently discovered, in about 25 kt breeze, that I can still only pull ropes with 3 fingers short and found it hard to furl the genoa, even though headed into the wind. Had to use the winch somewhat in the end.
Jun 5, 2004
241
Thanks a lot guys, lots of good advice as usual....sorry for the late reply...was out sailing. I'll core the line this week per joe & steve.
-cheers
