Local bottom paint knowledge for the Upper Ches.:
Bottom paint on the Upper Chesapeake, which varies at times between fresh to salty (brackish) and depending on the direction of the prevailing winds, how polluted the water and how 'extremely turbid' the water is ... is usually a crap shoot. Plus, the Upper Chesapeake is in the beginning stages of Zebra Mussel invasion.
By crap I mean literally and figuratively.
Mahogany Tides (explosive growth of toxic microorganisms) will surely cause SLIME accumulation on a hull and the slime will allow 'hard growth' (Barnacles, etc) to get a good 'foothold', even on high copper content paints as the slime will 'seal off' the copper action.
Other factors include the water flow or stagnation characteristics of exactly where you moor or slip your boat.
For the past few years, especially on Worton Creek, bottom paints with Biocides to prevent/retard slime growth have worked the best. Example: Interlux "Ultra", etc. .... But should be applied 'as smooth as possible' so that the slimes, etc. more easily 'release' when the boat gets up to hull speed, or you can simply occasionally 'wipe' the hull with a simple plastic/polymer 'squeegee' or very soft brush mounted to a long retractable painters extension pole.
For the 'easiest' way to get a relatively smooth hull with ablatives, is to 'thin out' the paint to the maximum specified dilution and use a THIN foam roller to apply on a relatively WARM day. The yellow WEST SYSTEM epoxy rollers are probably the best to use but the foam will eventually break loose due to the solvent/thinner ... so youll probably need at least 3-4 foam WEST SYSTEM rollers if you work fast and before the thinner/solvent ruins/dissolves the foam roller.
Consider to use a barnacle barrier on your prop and shaft: Petit Zinc Rich Barnacle Barrier spray paint.
The problem with most water based paints is that you cant get them 'smooth enough' as you can with solvent based ... and you dont want 'rough' when massive slime is the prevalent problem.
As you already experienced, with toxic 'mahogany' tides causing great amounts of slime and its accompanying great barnacle attachment, the debris falling off a hull when scrubbing is extremely toxic and can cause violent reactions to human skin, mouth parts and to human respiratory tissue. So, anything you can do to help to keep the toxic slime off will be of benefit.
You're a nice guy; but, I really dont want to consider doing "mouth to mouth" on you, ... like last time. ;-)
