Boat weight on centerboard
I just picked-up my new used '94 H26 last w/e and I'm in the process of rebuilding the trailer. It was used (trailer) extensively by the previous owner, but not well maintained. Besides a complete top to bottom brake replacement of all brakes, lines and actuator, I plan on looking into the reason behind getting a worn spot on the centerboard where it rests on the white plastic piece on the trailer crossmember. I'm assuming this is due to too much weight resting on that point as mentioned by others here. In fact, when I first saw it, I thought it should not even touch that far down. My boat, when on the trailer is so far forward (and yet still hangs a good 24"-30" of the back of the bunks) that only @ 12"-18" of the bottom part of the centerboard touches the carpeted lower "keel" bunk. I've wondered why the bunk was installed so far back. It seems rather useless leading me to believe there could be an issue with the way the boat is sitting on the trailer in the first place. I've read here about raising the bunks so I'm going to look into that. I may replace the bunks with all new lumber to give it more stiffness as well. I'll keep checking all your comments for any tips you have all perfected. See you on the water!-Pat
