Vented Loop
Hi Bob,That vented loop is a common problem. Mine leaked badly on my 340, all over the engine. Finally it broke and REALLY sprayed water. If you have the original one that's a metal U shaped piece with a white plastic valve you might want to replace the whole unit with a new one. Vetus makes a nice one that can be cut to fit many sizes of hose and can also be run off with tubing so any spray goes in the bilge. Normally there shouldn't be any water coming out though. Good luck!
