They are tough as hell. But with air temps of high 80's the best you can expect in 3 days is ice that turned into cold water. BobAre the yeti coolers that good or over priced for what you get
I get that you don't like coolers!coolers are a part of cruising if you enjoy having things in your way when you need to access the space below the cooler...then the next place whereto you moved said cooler and you will find you are no longer using said cooler and give it away, as did..
We have an engel cooler that we run as a freezer. Draws maybe 40 ah per day. Lless than the AB refer. Keeps steak and ice cream rock hard. Tough on beer cans though.Another thought....the really nice plug in fridges that resemble coolers. What do you think it would take to have a strong enough battery bank to use one of these? It would probably be cheaper to have a cooler and buy ice if you figure that with the fridge you have to up your battery bank, possibly add solar, or go into a marina quite frequently to keep your batteries up. Any thoughts on this?
Sounds like a good plan after all you are in Margaritaville!ok guys...wanna hear the plan???
as i am not a cooler or fridge person, to date...i am going to be renovating my formosa..it has a bad beam under where fridge drained on it for ever, and rotted it out..this beam also is mizzen step and support for battery box..
ok
so we are going to get to guaymas to do this... remove the crap that is rotted, and shore up the beam and make a space to install 1 or 2 engel or dometic or some such..one either ice maker or freezer and one fridge..
omg, you say. that one is gonna do a fridge!!?? the world must be coming to an end...havent had that luxury since i left my apartment in 1990 for my first boat.
whoot...lol...we gonna be living larger....lol
so, when the time comes, with pictures and arrows and a paragraph on the back, we will present the conversion in `pix on forum when it happens... should be within the next couple of years....first engine, then tank, then beam... then ......
and the magic boxes will be installed and not travelling in their own circles as i sail.....
