Assuming you have enough coolant in the system to run the engine without overheating, follow Ralph's advice and take off the radiator cap to check the coolant level. Then run the engine, with the cap off, in order for the thermostat to open. Just keep and eye on the level and add some more if it goes down while the engine is running. Just make sure you are adding the same type/brand of coolant that is already in there.
