Possible gushing explaination
I found out the hard way that the engine often has air pockets captured in the coolant system. This has caused mine to gush, but more troublesome was the overheating, esspecially during the first trip of the season.i spoke with the techies at Universal, and it was suggested that I attempt to relieve the air pockets by repeated momentary racing of the engine. This did work for me, I found an easier, but grundy methoud. With the engine cold, slightly loosen the air vent (wing shaped, about 11/2 inches wide on top of engine, loosens by turning counter clockwise.)use your lung power to blow into the air vent, you'll send some antifreeze into the reserve tank. Now open the engine coolent cap, and add antifreezze as needed to bring the level up. Repeat this as needed, about three time. Remember you'll have to also remove coolent from the reserve tank, or it will over flow. This can be the antifreeze you add to the system.I do this at commisioning and run problem free all year.good luck
