Hi, I just wanted to alert you guys to a cool planet alignment in the western sky at sunset. Immediately after sunset there are 4 visible planets that will line up starting just above and to the south of the sunset. They will be in a rising line to the south. In order they will be Mercury, Venus, Saturn and Mars. Hold your fist out at arms length and all 4 planets should only be slightly wider than your fist. Actually, I don't want to mislead you, these 4 planets will be grouped together around sunset for several weeks but the alignment will change as time passes. First Saturn will pass Venus then it will pass Mercury on it way to passing the Sun. Venus passes Mercury sometime after Saturn does with Mars catching up sometime next month. Actually, all 5 visible planets will be visible at sunset. The 4 I just mentioned and Jupiter will be just above the Southeastern horizon at sunset. Jupiter is very bright and crosses the southern sky as the night progresses.
The chart shown is from my PA location (40.032*N 75.828*W) but should be accurate from anywhere in the Northern Hemisphere. Large lattitude differences would alter the relationship to the sun but the timing relative to sunset and the planet's alignment relative to each other should be the same. If you are wondering why the starchart appears to be backwards with east on the left and west on the right, it is designed to be held above your head to match your sky view. When held above your head with north pointed north the east and west horizons are oriented properly.
Get out and check out the sky, it's pretty cool,
