If the rig is 3/4 fractional and has an extrusion that relies on the runners they cannot be eliminated by moving the forestay and uppers to the masthead. They will still be needed to support the upper part of the mast. Also if the forestay is moved to the top of the mast there will not be any forward support of the mast section below the masthead as originally designed. Without the support the forestay now provides and without runners (which the op wishes to eliminate) the mast, being a section designed to be tweaked, will probably invert.
I think these changes will require a new stiffer extrusion - either during the re-rig or when the mast goes over the side if not done properly. And the damage that does can easily exceed the cost of a new extrusion.
If the boat is as bad as the op states currently, it may have been created (not properly engineered) by someone who didn't have the proper skills. To re-do the rig without expert advice (as opposed to internet advice which is often worthless) is likely to end badly - maybe worse than the current rig.
Hire an expert for at least a look and consultation. Rig design is not a simple exercise.
