Not so Fast
Be aware that you may end up with unintended consequences if you just move the forestay up to the masthead without any other rigging changes. On most fractional rigs, the upper shrouds only go as high as the forestay, they do not go to the masthead. The section of the mast above the original forestay attachment has no side support. A genoa or spinnaker flown from the masthead could put loads on the top section of the mast that it was not designed for.
I found this out the hard way on my 23' Venture of Newport cutter. Both the inner and outer forestays originally terminated within a foot of each other on the mast. She was what you might call a "fractional rigged cutter." The previous owner changed this, moving the outer forestay to the top of the mast. Being none the wiser, I liked the idea and kept it that way.
The masthead rig had several advantages: it opened up the slot between the jib and staysail, preventing the jib from backwinding the staysail. It made tacking easier. It allowed me to fly the jib up higher in light air. It allowed me to use bigger sails.
In time I acquired light air drifter with a masthead size luff and an asymmetrical cruising spinnaker. I was day sailing in light air on Lake Superior when I was surprised by a line squall that came up from behind. I had the spinnaker up at the time. The force of the wind knocked Chiquita over so far that my little 5 lb Hi Tensile Danforth stern anchor tipped out of its bracket on the transom and went in the water. The boat anchored itself by the stern! The squall lasted only a few minutes during which I was able to pull the sock down over the spinnaker. I didn't notice any damage and returned to the dock, much humbled. The next day, with some friends as crew, we departed Duluth Harbor for a 90 mile cruise to the Apostle Islands. The mast was perfectly straight when we left, on starboard tack. When we switched to port tack the top would bend about 2' to the side. The mast was "sprung."
My insurance company agreed to pay for a new mast so I ordered a new blank extrusion. I wanted to keep the masthead rig so I did a lot of research and looked at a lot of boats with cutter rigs. This was before the internet so I spent a lot of time at the library. I even wrote to Ted Brewer and asked his advice. I included a number of sketches of possible alterations, including one with jumper struts and one with double spreaders. Mr. Brewer was kind enough to reply and indicated that the best solution to keeping the outer-forestay-to-the-masthead rig would be to move the upper shrouds to the masthead as well, move the spreaders and lower shrouds up to the middle of the mast, and add running backstays to oppose the pull of the now unsupported inner forestay. That is exactly what I did. This is how many cutters are rigged and it has been working well for me for about 30 years now!
The running backstays are not used in normal sailing, only in heavy air or when flying the drifter or the spinnaker. I have snap shackles at the bottom of their tackles and clip them to the original chain plates when not needed. There they serve as intermediate stays. I can also clip them to pad eyes on the cabin top to serve as "baby stays" to keep the mast aligned when raising or lowering it. Chiquita is, after all, a trailerable boat. I have discovered one other benefit of the runners that is becoming more important as I get older: they provide a very strong, safe, and perfectly positioned hand grip for stepping up from the cockpit to the deck or cabin top.
