Do I need to have an anti siphon on the waste line to the tank as the tank is well above the toilet height. Thanks David
No...vented loops are only required in lines connected to below-waterline thru-hulls. If the toilet uses sea water, you'll need one in the head intake. It does NOT go in the line between the thru-hull and toilet pump, it belongs between the pump and the bowl which will require replacing the short piece of hose the toilet mfr used with two pieces of hose long enough to put the loop 6-8" above waterline AT MAX HEEL, which on most sailboats puts it 2-3 FEET above the bowl. If you're buying a manual toilet, the installation instructions will include a drawing showing where to put it.
How high above the toilet will the tank be? 'Cuz that's gonna make it an uphill run from the toilet to the tank. Manual toilets can lift up to 4 ft, that's all. The inlet fitting--in fact, ALL the fittings on tank--should be ON the top of the tank with a dip tube inside the tankon the pumpout fitting-so your toilet discharge discharge line will have to be able to lift high enough to go into a 90 degree fitting. So don't put the tank higher than the toilet can lift bowl contents into it.
You're welcome to give me a shout via PM for help with plumbing your system.
--Peggie
