Has any one ever done this. My Capri has has a single back stay that is off center. I'd like to convert this to the dual with the Adjuster. Any one have any experience in doing this?
Patrick - Can you tell me more about your setup, or point me to a commercial site that shows it? I want to explore all my options before I settle on a "solution".pgudat said:.... have gone away from wire to a vectran (or similar) line. I also am using the new low friction rings to create a cascaded purchase system.
Yes, the off-center backstay is not adjustable with a line if I recall correctly. It's fixed.Chris said:Mike, I am curious as to why you would need to do a backstay adjustment with a Loos gauge. When I do all of my rig adjustments my backstay tension is off. Am I missing something?
I don't have any relevant pictures but I'll do the best to describe. I have a 3/16" spectra backstay that has a "kicker" (batten) at the top of the mast to keep it away from the mainsail. Then about 6' above the deck in the back, I end it with a Low friction ring. I ran about 6-7' of spectra through the ring making a 2:1 purchase. At the ends of the second 6' piece, I put another ring. Then I have a line running from the attachment point on the stern, through the second ring, back down the the attachment point through a turning block, through a turning block on the rear corner stanchion and up to the traveler location. The final purchase is like 8:1 I believe.Mike said:Patrick - Can you tell me more about your setup, or point me to a commercial site that shows it? I want to explore all my options before I settle on a "solution".
