Control Head for ST 4000 Issues
Aug 24, 2009
444
Catalina 310 Sturgeon Bay, WI
Anyone have a working control head for an ST 4000 wheel pilot? I had a boat fail survey because the autopilot won't tack to port (everything else works) but buyer wants the head replaced, or the full autopilot?
Anyone seen this problem before +/- 10 and +/- 1 work fine all directions, and auto tack to starboard? I never noticed it did't work, we always tack ourselves.
Let me know via private message please...
Russ
S/V Long Story
Jul 14, 2015
840
Catalina 30 Stillhouse Hollow Marina
Did you try redoing the setup? It could be the limits you set on rudder movement.
Ted
Jan 26, 2005
1,280
Are you looking for a ST4000 or the ST4000 Plus control head?
Jul 14, 2015
840
I don't have a rudder sensor, so that limit is not a setting I can access. thank you though
I don't either, but ine of the settings you have to go through is a full side to side rudder turn, stop to stop.
Aug 24, 2009
444
John,
Thanks much. After your second note we walked through all the set up. Did not see anything all that off, but made a few changes. (also adjusted % for auto tack) it now works...
Thank you
Russ
Likes: JohnVTX
