contol panel
tom
On the electrical Control Panel to the left of the stairs: Is there a site to view the amp amounts for each designated function. I need to buy new circuit breakers for the whole panel (fresh water damage)and don't know what to buy. The wires look fine. Thanks, TOM
H
Howard
Wiring Diagram for H-27 (1978)
Tom, I have the orig. electrical system diagram. Although the diagram does not specify the amps of the breakers It des specify the wire size. I think you could back track from the wire size to breaker size. From top to bottom the diargram says Steaming Light #16 (White/Green) Anchor Ligth #16 (White/Red) Running Lights #16 (white) Bilge #14 (Brown) Cabin Lights #14 (Blue) All of the grounds from the breakers to the busbar are #14 (Black). From the busbar to the grount is #10 (Black) I've been thinking of upgrading my panel (I already have a second panel in the rear or the port bunk which I'll remove. I'm thinking of replacing them both with two six fuse panels side by side in a fram that I'll affix over the Nav table/station. I'll also make it up to hold my VHF. It's a winter project I tried to scan the page but it the resolution is not too fine. I can fax it to you if you give a fax number.
Smokey
Need Diagram Too!
Hi, I could also use the wiring diagram, fax# 847-331-9754 thankyou thankyou!
Jun 2, 2004
5,802
Not marked?
My c/b's(old, 1979) are marked with the amperage. But the numbers are on the body of the breaker, behind the panel. Have you got the panel out and the breakers are unlabeled? I also have wiring diagrams with only the wire size. That is not too helpful except to know that #16 and #14 are very small wires and cannot handle much current, about 25 max for #16 and 35 for #14. Which makes me think that most of my c/b's are 20 amps. Might be the only thing that I do not have written down. :(
H
Howard
Fax on the way TO Smokey
Fax was sent at 10:05 PM EST. Let me know if the resolution it poor and I'll fax it again on Monday from my office at high resolution. HN
H
HN
Bac fax number?
Smkey, Tired to fax but it was a voice line. I assume that the voice I heard was yours.. Are you sure that 847 331 9754 is the correct fax number? HN
smokey
correct fax number
Hi, my bad. the correct fax number is 847-914-3545. thanks again!
