Considering 1992 Passage 42
Dan Stover
Hi, My wife is insisting we buy a boat??? I am considering a 1992 Passage 42 (also part of her master plan). She likes the layout and as she is fond of saying "if Momma ain't happy, ain't nobody happy." Are there any specific problem areas or anything else I need to be on the look out for? If it needs new sails (don't know that yet) I am considering changing to in-mast or in-boom furling. Has anyone out there made this conversion? What are the pitfalls (other than cost) and suggestions, pros/cons. What size autohelm seems to work well (6000, 7000, etc)? Thanks for your help. I have been "surfing" this forum for a few years and maybe will be an owner/contributor later. Thanks Dan Stover
Terry
Dan, we purchased a 1991 P42 two years ago...
mainly because my wife liked the aft cabin and layout overall. We are two happy campers. A couple of things to consider: 1. Call Hunter with the hull number and determine whether the model in question applys to their electrical upgrade recall. Not a big deal, and if it does Hunter pays for labor and materials. 2. Our boat came equipped with an Onan 8kw Genset and two heat pumps; main cabin and aft cabin. We like this config. Depending on your planned cruising grounds a diesel furnace (Wallas) would extend the season if your'e in cooler climes. A cruising chute makes a big difference, too. She is a wonderful boat, easy to solo, fast and stiff, and very comfy. We have the standard main sail plan with furling genoa. Hunter did a great job on this boat. Terry
Rich Wallace
None So Far
We purchased our 94 model a year ago and put about 150 hours on the engine, and around 1200 nautical miles under the hull last summer. So far we are super pleased with the boat. The interior is very comfortable (you will love the shower), the boat is reasonably fast at about 7.4 knots at 2800-2900, fuel economy is excellent at about 5 quarts an hour, it sails at 6 knots on a reach in 12 knot winds, and feels solid in all situations that we have seen so far. About the only complaint I have is that it is a bear to dock in a cross wind with the high sides and deck because of the center cockpit. Maybe I will spring for a thruster after we get it paid off. That aside, I think this one is a keeper. I installed a Raymarine Type 2S (short) ram with the 400 computer and a 7001 head. It has been an excellent decision so far. The A/P holds a course even in following seas and holds the boat arrow straight when the seas are calm. You will even find yourself using the autopilot in the marina when you need to look away for a few seconds. We have the Dutchman sail system and so far it has worked well. Like any main, you have to head up into the wind to raise, lower, or reef it. The full battens really help the sailing characteristics of the main. Hope this helps you.
Marc Honey
42 Passage
I say make her happy and you can't go wrong. What is the down side? The 42 is a great boat and other than the wiring recall/upgrade, I've heard of nothing but happy owners.
H
Henry Rozanski
Good ship
I bought a 1996 3 years ago, fully loaded, and we love it. The only complaint is leaky rear cabin windows, but they can be recaulked with a little determination. The Front hatch leaked like a champ until we pulled it and recaulked it and now, not a drop! We have the Autohelm 7000 which does a great job - it steers alot more than I do (I prefer to play with sails and read). Make sure you get a generator and heat pumps. This floating condo deserves all the comforts. I have a furling "in mast" mainsail. As long as we're careful about tensioning when reefing, it's a very versatile sail configurer which gives up very little to full roach alternatives. Best of Luck. As you can see, everyone loves this boat.
Terry
Furthermore, I compared the P42 with the 420...
a different boat. The P42 is built from the 43 hull mold. Its actual length is 43' 10" with the bow roller and 42' without. Displacement is about 4,000 pounds heavier than the 420, which is built from the 41 hull mold. Check the archives for more P42 information. I've written many articles (as have others) about the various systems and mostly minor problems that we have experienced these past two years. We really like the center cockpit design. Its high freeboard can make docking dicey against unfavorable winds, but that is the case with most all modern shoal draft boats. Ours has the original CNG system; supplies can be problimatic off shore. I carry a spare tank with no plans to convert to propane because of the cost benefit ratio. Terry
G
Gordon Myers
P-42 Great Boat
We had a 94 P-42. The autopilot: You can get by with a Type I but a Type II motor will work better if you are going to do real cruising. The Type I is good to the displacement weight of the P-42. The Type II is heavier and would / will be better in heavy seas. The head type is really not important but we had a 7000. The CNG fuel (as mention by someone else) for the oven can be a problem if going outside of the USA. My only concern is that you inspect the Stainless Steel holding tanks. These over time will leak at the seams and need to be replaced. This is both costly and a smelly problem. Good luck, you will enjoy the boat Gordon s/y Utopia III (h450)
Terry
Gordon raised an issue to consider when ...
buying any boat, but some P42s came with an aluminum holding tank and some with SS. Our 91 P42 has SS and it does not leak. We did have a problem with the tank vent, which took me awhile to locate and fix. At first it was the scupper that was plugged then it was the bronze elbow at the tank that the vent hose clamps to. Check the archives for articles that I have written on proper holding tank and vent maintenance. I'm convinced that if you follow this procedure your tank will remain trouble free. I did find out an interesting point about aluminum holding tanks. Salt water, including urine, left to stand betweeb cruises will break down aluminum welds making them porous and leaky. Peggy Hall mentions this often in her articles. The holding tank on a P42 is located beneath the sole on the starboard side of the main cabin. It is easy to have the tank checked out by your surveyor before signing the purchase papers. While you're at it make sure the top loader freezer freezes and the top and front loader cooler gets cold. Check both reverse cycle heat pumps to make sure they heat and cool. By all means first open the raw water intake through hull for the heat pumps before turning them on. The aft cabin heat pump is back by the steering quadrant. The main cabin heat pump is beneath the starboard setee. The P42 has many systems and I would check each one out yourself before buying. Your surveyor should do this for you, just be sure you are looking over their shoulder as they do it so that you know it works. Our surveyor took eight hours to do our boat and uncovered several mostly minor problems. Terry
