connecting rudder to outboat
21
hunter 93 23.5 doylesown
just bought a 96 23.5
but just moving from it to my slip was very hairy having to use both the out board and the tiller
is there a way i can hook them to together so i dont have to juggle both hands
Jul 1, 2010
990
Catalina 350 Port Huron
There are kits for that, but I just leave my motor pointed straight ahead and use the tiller for steering. There are times when adjusting the motor also is helpful, but those are few and far between for us. We usually don't bother.
Apr 27, 2010
1,279
Hunter 23 Lake Wallenpaupack
I do the same as sesmith. I find it fairly easy when needed to twist the motor, as I sit on the port side when steering near docks. You will need to be able to reach the throttle and shifter in any case, unless you have a remote cable. I would think there are times you don't want the motor turning.
May 9, 2010
131
Hunter 23 WIll be at a Navy base
motor
I have a 4cycle 5 hp. It has a way to lock it in any direction. I hardly unlock it and just use the rudder.
Ashley
Dec 2, 2003
111
Hunter 260 NC
I 2nd the ez-steer, works great and very easy to disconnect when you want to sail without the extra load on the wheel/tiller. Boat will spin a nice tight circle when the two turn together. You'll be docking like Capt. Ron in no time :)
FWIW, seems like I remember this topic a few years ago and several posters were making their own homemade verisons pretty cheap. Might be a treasure or 2 in the archives...
Hunter 26 Illinois
Home made tiller connection
Here's what I did with two eye-bolts and a piece of stainless rod. I used someone else's idea of not connecting it at the tiller but just drop the rod in and can take it out to tilt the motor or to put away for trailering.
This is a remote unit motor so it has a plate on it for connecting that I put the eye-bolt in, but I would guess that a tiller unit might have the place to attach the plate if you wanted.
81
Hunter 270 Ottawa
Connecting Rudder to Outboard
I have had a connection between the rudder & outboard on both of my boats, including the current 2002 Hunter 270. I would not want to be without that connection, as it works beautifully and is a safety aid in difficult conditions when docking. I bought the stainless steel connecting rod from West Marine for about $70. It takes a bit of work to set up the connecting rod system, but it is worth it.
