I picked up an H23 for cheap money last fall. Over the winter some water got into the boat. I intend to find the leaks but my question is about water not passing to the lowest point in the boat and collecting in the several separate bilge areas. The 3 lowest bilges (keel attachment area) in the floor in the main cabin appear to be connected by small weep holes but it appears that water collecting in areas in the v-berth and under the settees does not make it into the bilge at the keel? Any suggestions about connecting the many different holds so that water can flow to the lowest point?
