sorry, but I'm way past 11th grade.
I understand the math. It's solar and controllers I'm fuzzy on.
Wanted to know what the true specs were that might be getting to the batteries, given a standard of operational protocol for mppt controllers and the specific panel specs.
It can be a complex question apparently. But I was hoping for a simple answer. That is: does the controller change other specs like a power supply/transformer, or is it only voltage. --couldn't find those specific specs-- If it is only voltage, then I can assume that current at 12v for 100 watts is 8.3 amps, and make further calculations based on that. The calculations will be analyzed with your and others' expert additional variables.
The end is that I'm calculating requirements for long range coastal cruising with no shorepower, with the boat's estimated consumption as equipped, during both sailing and mooring, and estimated durations of each.
I'd like to get a flexible panel for the Bimini top, with no other used space. LED lights, low draw G76csx GPS. No refrig or air cond, nor any other high draw equipment, with the AP and maybe VHF/AIS being the most.
