If I get a Grape Solar Photoflex 100w panel, I'll need to also get an MPPT controller.
The panel is rated at 100w, 17.8v, equaling 5.62 amps of current. So, If I install the controller which brings the volts down to (example) 12, will that bring the current up to 8.3 amps? What is the reality of specs actually getting to the batteries, since I presumably can't let 17.8 volts pass through?
Also, anyone use Grape Solar? Comments?
