Agreed that it wouldn't be good in series, but personally I'd never run panels in series on a boat anyway. I don't see any real gain in doing so other than some savings on wiring but possibly large losses if any shading occurs. On a house installation it can have benefits.I would agree not many probably would try it... but Walt did, and gave us some surprising numbers... but in series, I think there would be a problem....
I started with a 40 watt panel and then added a 60 and then a 100 watt panel, all going to a MPPT Blue Sky 2512ix and it has worked fine. Maybe not optimum but I believe close to optimum. To do this they recommend panels that work at the same voltage and of the same cell type and all 3 panels meet those criteria.
I've since added six 60 watt panels and I did make sure all of these were the same and even bought an extra one in case one broke in the future. I have 4 of them wired in 2 pairs that are in series all the time that run to an MPPT controller putting out the correct voltage to charge a pair of 12 volt batteries in series (24 volt bank) for a trolling motor. The other 2 60 watt panels can be switched to parallel and connected to the 2512ix which is connected to the house bank or switched to series and their output sent to the trolling motor controller and its 24 volt battery bank.
If needed the 24 volt bank can be switched to a 12 volt bank and used at night as a house bank also.
http://purplesagetradingpost.com/sumner/endeavour-electrical/electrical-index.html
On the Endeavour I sourced all the panels as 80 watt panels and again bought a spare as at times they change the dimensions of the panels and I wanted to make sure I would have one that would fit the array if one was damaged,
Sumner
1300 miles to The Bahamas and Back in the Mac...
Endeavour 37 Mods...
MacGregor 26-S Mods...
Mac Trips to Utah, Idaho, Canada, Florida, Bahamas
