Size matters
I agree that marine products are frequently way, way over priced just because they have a marine label on them. It's always a good idea to shop around and compare specifications before ordering anything from your marine store.I've always thought it a good idea to use standardized or at least very popular fitting sizes for any holes drilled in the boat so if replacement is necessary due to defect, damage, or in adequate design, another product would fit the hole. The most popular vent sizes are 3" and 4" for a reason; they fit in more situations, and many makers have products to fit in the hole. I think you were wise to purchase a spare.I'd be pleased to see a report from you about the results of your mounting the unit in the vertical bulkhead. I've not considered that kind of mounting due to fears that water would find it's way in in a heavy rain. In any case, I think the best units, are those that can be completely closed from the inside to make them watertight. The unit I have has a on/off switch so the unit can be stopped when it is completely closed for water tightness, without removing the battery.Ventilation is a necessity, passive or forced. Thanks for sharing your choices and experiences with us.
