On my O'Day 23 condensation during the cooler months never seemed to be an issue. There was a little, but not really noticeable. (I did a full winerization to her each fall and had to wait until spring to use her again.)
This will be our first winter on our 1985 Catalina 30. It has an A/C with reverse heat that we are leaving on. We went up to the boat for some sailing, and when I went below I thought something had sprung a major leak. EVERYTHING was soaked. The cushions, the rugs, everything everywhere was wet to some degree. In the morning when we awoke we saw the cause, condensation was over every window and some portions of the cabin roof. (Especially the vBerth) There were heavy large drops of water that were dripping all over the boat.
QUESTION: Is keeping the heat on a bad idea? (Boat is in Lake Lanier, outside of Atlanta GA.) It does get cold here at night (Usually mid-30s, but once down to 6 degrees) during the winter, but we want to be able to go out on her when we have the chance, so we don't want to do a full 'WINTERIZATION' like I did with the O'Day. Are the chemical desiccants a viable idea? I've seen them used in houses, and they can be a bit of a mess. What do others in marginal temperature areas do so they can still sail during the Fall/Winter months? Am I wrong to think keeping the heat on will make winterizing the fuel and engine, fresh water, etc unnecessary?
Thanks!
Thanks!
