Condensation in closets
Mate
My question is to those living onboard in colder climates. How or what do you find works best for the condensation problem in lockers?
P
Peggie Hall/Head Mistress
Leave locker doors and hatches open
So that air can circulate through them. If that's not practical, replace solid locker doors with louvred doors and/or install vent panels.
Ron Hughes
Removing condensation aboard
Mate, In my experience condensation occurs aboard primarily as a result of lack of air movement. While improving air circulation in lockers etc. aboard is one component of ending your problem, moving air thru the boat will eliminate it. If you are living aboard, your breathing is constantly adding moisture to the air in the boat. The burning of any propane aboard (such as cooking on a propane stove) adds even more moisture as water is a big component of the waste gases of its combustion. If you are heating your boat consider plumbing an outside source of air to the furnace/heater. The forced addition of heated air to your cabin will eliminate any drafts aboard as a result of the positive pressure(warm air seeping out, not cold seeping in) . Any leaks (around the companionway slider etc. will be the escape route for your moisture laden cabin air. In my previous boat I installed a Webasto air heater in the engine compartment. I took the air for heating from inside one of my cockpit lockers thru a 4 inch PVC duct to the heater. In my current boat I added a bilge blower fan on a timer to the factory thru transom vents. Every day at 3 o'clock in the afternoon it runs for 15 minutes. This addition of a massive volume of fresh air eliminates my moisture problem as I do not live aboard. A pair of solar powered vents such as those from Nicro will do the trick too, but they don't move nearly as much air as a bilge blower can. With the success that I've had previously, I plan to plumb an outside source of air to at least one of my "Red dot" heat exchangers in my current water heat system to effect the same positive pressure solution when I am having an extended time aboard. It works amazingly well. No condensation at all, even when there are four aboard constantly. No more wet toweling windows! Happy Sailing! Ron Hughes, S/V "Best Revenge" H 40.5
thomas e mcnamara
WE LIVE ABOARD ALL YEAR AND FOUND THE SAME PROBLEM IN SAILBOATS BEING THAT EVERYTHING IS ON THE EXTERIOR BULKHEADS.THE SAILBOATS DO NOT HAVE AS MUCH FINISHES ON THE WALLS.AS SOMEONE ELSE SAID WE HAD A WEBASTO HEATING SYSTEM INSTALLED.IT HAS TWO ZONES ON THERMOSTATS,AND ONE ON EACH SIDE THROUGH ALL THE CLOSETS BEDDING,DECKS ETC THAT RUN WHEN EVER THE HEAT IS ON.IT WORKED GREAT EXCEPT THE HATCHES WHICH I INSTALLED BUBBLE WRAP ON THE SCREENS AND NOW I HAVE INSTALLED A DEHUMIDIFIER AND EVERYTHING WORKS FINE. THE ONLY PROBLEM TO DATE IS THAT WE BOTH SMOKE MCBUBBA720@AOL.COM IN GLEN COVE NY
