Condensate Filter replacement & LED Light parts
16
Beneteau 37 Georgetown, MD
Does anyone know where I can obtain this part. It is a condensate filter for the AC system on a Beneteau 37. Lives in the bilge next to the depth and speed transducers. The inlet fitting side broke (not exactly sure how/why) but I am unable to find this part on the parts website nor a manufacturer website.
I'm also looking for the small white screw covers that attach to the LED swivel lights located throughout the cabin. I am not interested in buying the hole light assembly, and wondered if anyone knew the manufacturer?
Thanks,
Sean
Cwoody
Aug 10, 2010
87
Beneteau 423 Galesville, MD
Is this part of a venturi system or are you are filtering the condensate water before it gets dumped into the bilge?
You would probably need to go to the AC manufacture to get this part. I installed al a venturi system .... no condensate in the bilge.
Apr 9, 2012
16
I will try calling Beneteau. I searched the parts site and couldn't find anything related to the A/C system. I believe it's a Webasto. This filter is not part of the system, but appears to be a seperate manufacturer. I'm not totally sure how it works, but it consists of this and a seperate power module that plumbs the A/C condensate into the A/C water discharge out the side of the boat, rather than draining into the bilge.
Cwoody
Aug 10, 2010
87
The Mermaid Condensator kit includes a Shurflo strainer to filter the condensate water, similar to the one that Defender sells here:
http://www.defender.com/product.jsp?path=-1|51|2234255|2234258&id=121366
that you could make work.
Here is a pic of the system I installed. Instead of draining condensate into bilge, I direct to a small collector and Mermaid Condensator tapped into discharge line:
