I was looking around the other day, and researched the spec's for some 120mm computer fans. Yup the big suckers. Well I found on that will move 110.5cfm and draws 0.5A. It was variable speed and included the speed control so you could adjust the speed/noise from 17-29db. I am thinking about building a new door for the night time while at anchor. If I used some rubber isolators /seals to reduce vibration from the fans to the lexan door do you think that a pair of them would provide a reasonable air flow through the cabin?Anyone try this? Alternate thoughts?
