Roland, you have hit on the very thing I have written about here about 800 times!
Here is the link to the old post--
http://forums.sailboatowners.com/index.php?threads/post-compression-help.148755/page-2#post-996161
Here, for what it's worth, is my blog post--
http://dianaofburlington.blogspot.com/2013/01/the-crucial-duty-of-compression-post.html
Don't know why the print looks so small. But it's from the 'old' site format.
The 'fix' I have been advocating about this is to make a 'bulkhead' of fiberglass athwartships under the sole there, to strengthen the sole itself to hold the mast. This could be made of fiberglass board (like from McMaster-Carr), could span the whole space, could be fitted with an longitudinal blade for stiffness, could be fitted with limber holes, and, most importantly, be tabbed in (structurally) to the sides of the hull to either side. This would spread the load, sufficiently and to the right places. The point I was making was that standing the mast on the keel itself (or transferring the load directly so that in effect it's on the keel itself) is patently
bad engineering. Remember the mast is the arrow, the rigging is the bowstring, and the hull is the bow. You're trying to shoot the arrow through the bottom of the keel. If the bow works at all (and it does, in this case), then it's going to apply a load there-- to the bottom of your hull. And guess what the bottom of the hull is holding on?
In short:
never compound loads from separate duties in the same direction...
especially in a stressed-skin structure.
Even amongst industry leaders, we have all become soft about idea of fiberglass being a wonder material for boats. We think it can do anything, that it doesn't rot, that it's strong, that it's maintenance-free. All of these are myths, not even close to being true in the real world. Stressed-skin boats receive a variety of loads at a variety of points, often without being understood. Your chainplates pull up on either a (rot-prone) plywood bulkhead or a cored fiberglass deck. Your mast step presses down on a cored fiberglass deck. Your keel pulls on a fiberglass eggshell. And fiberglass isn't as good in tensile, especially when point-loaded (equivalent of clevis pin in hole drilled through 'glass) as most people believe. Where's the strength and the support? 'It's
fiberglass; it doesn't need it!' --
bah.
Even considering maintaining and rebuilding the existing aluminum block under the H30 sole is,
technically, a waste of time. Sure; you can make the existing system work again, as apparently it did for three decades or more. But it's a bad system to start with and, when the occasion permits, should be replaced with a proper support structure.
Some rules of thumb:
1. Avoid the installation of structural metal in the bilge.
2. Avoid the installation of structural plywood in the bilge.
3. Avoid the installation of structural mahogany, teak, oak, ash, and other hardwoods in the bilge.
4. Whenever you face a load of any kind, in a stressed-skin boat, spread it as far and as evenly as possible throughout the skin. This means tabbing large-ish supports into wide areas with adequate 'glass work. Point-loading stressed skins is a recipe for failure (distortion, delamination, and, in worst cases, puncture).
5. Stacking things for strength is child's play. Arranging blades, aligned with the axis of the load, is far lighter, stiffer, and thus better. (Anyone else notice that, if using an aluminum I-beam, that Hunter placed it in the wrong attitude? It should have been standing up, not lying on its side!
I conclude that the fabricated fiberglass bulkhead, adequately fitted into the space, in line with the load of the proper thickness (wouldn't go less than 1/2" here; 3/4" better) and massively tabbed in-- and then furnished with limber holes to permit water to flow by-- is the only *proper* way to solve this once and for all. This can be easily made up, worked into place, and shimmed or even caulked in 5200 prior to laying up 'glass on it. Do this, and the problem shall not recur in your and my lifetime put together.
Now if only Hunter had done this from the start!
