Compression post removal
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
Woohoo! Back from our BVI trip today! have to get used to wearing shoes again.
I have a question about removing the compression post if/when we decide to reinstall the table. The mast is down. I tried removing it once before when we first brought the boat home by removing the bolts at the base, thinking it might drop down if I swung it off the structure. It didn't budge. Do I need to remove the top cap screws too? It looks sleeved.
I have all of the parts from the PO to put the table back except the pulley missing in the 3rd pic. SBO found one but the hole dimensions didn't match. Any ideas where to locate one? It supports the counterweight to adjust the table height.
Oct 30, 2011
542
klidescope 30t norfolk
Wires run thru it ? My H30 looks similar but it has wires in it if yours does got to pull them out and yes top bolts keep it from pivoting might need use car Jack with 2x4 next to it and slowly take a little weight off it
