Bob Gravenstine
Last year I had a small leak around the compression post on my H26. This was not the first time. I thought I fixed the leak a few years ago but it has returned.I have pulled the post and have begun to clean up the polysulfide used to seal the area around the post.What is the best way to remove all the old sealant and how should I correct what seems to be a very uneven bore for the post?Also, how should I smooth the bore in the deck where the post enters? I have considered cutting back the core material and filling with epoxy. Then I have the problem of returning the bore to the proper size to accept the post. It is almost impossible to redrill the opening without a solid center for the pilot drill.Any suggestions from someone who has done this kind of job is appreciated. Without a new direction, I will just be recaulking with the polysulfide and hope I do a better job this time.
