Brigg
A few weeks ago I posted a photo and information about a leak at the base of the compression post on my H260 (see photo). In preparing to fix it, I notice that their is a lot of space between the metal base that sits atop the keel trunk and the sides of the compression post which sits inside the collar on the base. It's as if their should be a gasket of some sort sealing the connection. When I went to apply some 5200 sealer I also notices their was still water inside the base, even though the boat has been on the trailer for three weeks. It has been raining and as it turns out the water is coming down the compression post from the roof below the base of the mast. Is it likely that I'm missing some sort of gasket between the metal base and compression post? The compression post is also very loose inside the base and can be moved around an eight of an inch by hand. This dosen't seem as though it is prividing much support for the weight of the mast. I'm now wondering if just sealing between the post and the collar of the base will do much good if the post can move around so easily. So, 1. Am I missing an important gasket that the compression post should be sitting on and: 2, How best can I stablize the connection and seal it? Information and suggestions are welcomed.Brigg.
