Bob
I have searched these forums for 2 days and have not found any relevant information regarding the compression post on these boats. I've found a lot of partial info but nothing complete. Mine seems to be failing due to possible corrosion at the base. The previous owner decided not to tell me about the extent of the corrosion which the surveyor also missed. The previous owner applied an epoxy coating to the visible portion to conceal the corrosion.Does anyone have specific information on a successful replacement of the compression post? For example, does the mast have to be removed or can the cabin ceiling be raised /supported by a jack while the post is removed? What's the attachment at the top of the post? It appears that the base is glassed in. What methods have been successful in refastening the base? Does it require re-glassing? Photos would be greatly appreciated.Also, the rudder needs to be rebuilt. Does anyone have detailed information on rebuilding this rudder? I've heard some rudders are rebuilt with Coos composite boards and then glassed over. Photos would be helpful here.Thanks in advance,Bob
