Compass Variation?
Dan McGuire
Not that Complicated
You can swing your compass using a GPS. It is easy, cheap, fun, reasonably accurate and takes less than an hour. You can also obtain deviation. See my post below. The one thing I did not mention in the post is that there can be no current or tide. I believe the accuracy is good enough for virtualy any sailboat application, since under sail, the sailboat can have a quite of bit of leeway. Comparing the GPS and the compass, I have seen leeways in excess of 10 degrees. By the way, the term "dip" rings a bell and I might be confusing it with declination. As someone mentioned, the only two terms important to sailors are "variation" and "deviation".
G
Gord May
Tutorial from USCG
Here's a link to a Coast Guard Tutorial on Compass Error etc. http://www.auxetrain.org/magnetic.htm Explains it all.
Dan
GPS as a compass?
I have a Garmin 176C, it has a compass with speed and lat and lon on one page. I am correct in the previous post reading that the compass (on the GPS) only points in the direction Ive been?
Mike C22
GPS question
If one is using a GPS, and they have set a waypoint, wouldn't the GPS show them how far off course they are? Also, if one is using a GPS, and the have a chart available, shouldn't they be able to figure out their position with the co-ordinates?
Ron
Magnetic Declination = Magnetic Variation
mag·net·ic dec·li·na·tion noun difference between magnetic and true north: the angle between magnetic north and true north at a particular point on the Earth’s surface. Also called magnetic variation Also called variation
