I'm mounting a Plastimo Mini Contest Compass on my bulkhead where an old compass had been mounted previously (there's an air vent present now). I'll have to patch some screw holes (from the vent) and shim the compass to make it parallel to centerline, as the bulkhead on my Macgregor 25 is angled to some degree. Any suggestions on how to determine the correct amount to shim and how to install it so that it will be sealed and fairly easily removed in the future? Do I have to seal the screws in this situation? Finally, do you recommend a backing plate, or is that going a bit overboard? Thanks.
