Compass and multifunction display
Quoddy
Apr 1, 2009
241
Hunter 260 Maine
We are adding a compass to the wheel area and already have a Raymarine C70 built in. On another forum I read that some units require a good amount of separation. I checked the Raymarine instructions and they say 3 feet. I tested the compass with the C70 on and off and the compass was steady at 3 inches from the display. Does this experiment settle the interference question?
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
No, because the interference may only show up in certain directions. It may have no effect when the boat is headed north or south but effect it considerably when headed east/west. You'd really have to swing the compass before declaring it fine.
Quoddy
Apr 1, 2009
241
Hunter 260 Maine
Magnetic north
The boat isn’t in the water and the compass enclosure will be difficult to construct on the mooring. I was thinking, I might be able to get similar results by testing the compass on all sides of the C70. This would change the relationship between magnetic north, the compass and the C70 .Might this yield similar, but not exact, results to moving the boat through 360 degrees?
May 25, 2004
981
Catalina Capri 14.2 1670 Rochester, MN
I was on board when a professional swung the compass on our 40' ketch in the early '70s. We ended up with several small magnets fixed around the compass to correct for deviation on very specific headings. You can't predict the outcome without going through the process.
Feb 6, 1998
11,772
Quoddy,
You can install whatever you want but you should then have the compass professionally swung. There is Charlie Cook out of Yarmouth and Bob Witherill in Belfast. This needs to be done in the water with the instruments running how they normally would. They will usually first adjust the cardinal positions then check the inter-cardinal. When done they will leave you with a deviation card. Best money you can spend in Maine...
Oct 22, 2008
3,502
No, this generally won't work, as the physical relationship of the display needs to remain the same relative to the rest of the boat as well as the compass, so doing it with the boat on the water or using a travelift is the only way. :D
Quoddy
Apr 1, 2009
241
Hunter 260 Maine
Thanks
Thanks for the help on this one. I tried the compass on all sides of the display while turning it on and off and running various features. The compass was rock steady:), so I will build it in as planned and then move to the on the water adjustment.
Bob S
Sep 27, 2007
1,815
Beneteau 393 New Bedford, MA
Dog,
Can you recommend a few people in the Buzzard Bay area that do this?
