Companionway Trim Re-Bedding
Mar 11, 2010
292
Catalina Tall Rig/ Fin Keel Deale, MD
We have a 1984 Catalina 30 and rain has been leaking into the cabin from around the companionway trim. I've removed all the boards and will refinish them but I would like to get a recommendation for re-bedding the boards back in place. It appeared to me that the original bedding was plumber's putty due to its characteristic yellow color and softness. Is butyl tape the newer, better product for this job? I know it's recommended for all other deck applications.
Rob
Apr 8, 2010
1,606
Frers 33 41426 Westport, CT
For rebedding the wood life caulk is often used, but I beleive butyl tape would do a fine job as well. Whatever you do, don't use 5200 (just in case you were even thinking it)!
Dec 5, 2011
559
Catalina Catalina 22 13632 Phenix City
I pulled all the trim off of my C-22, cleaned, sanded, re coated with Cetol and then re bedded with Butyl rubber and so far, haven't had the first leak. I applied a small amount of butyl around each screw hole and then bedded each screw head with butyl and slowly tightened everything down on a warm day. It worked well for me, good luck with it.
Sep 2, 2011
1,041
Hunter 27 Cherubini Alum Creek State Park
Did you cover the entire underside of the trim piece with butyl tape, or just a bit around the holes? I re-did my sliding hatch rails and had way to much tape on them. I had a hard time getting it to squeeze out and was concerned about stripping out the holes in the wood.
When I pulled off my Catalina trim boards, there was just a single line of silicone down the middle hitting all the holes.
Mar 11, 2010
292
That's kind of what I was wondering. Making it thin enough so the boards would pull in tight, using a heatgun to soften it (working outside this winter), strategically placing it to block water intrusion, etc. I do appreciate the input.
In this location I was also wondering if there would be any oozing, from out behind vertical trim pieces, due to 105 deg weather later this summer? The plumber's putty is soft and I know it handles water around sink drain fittings pretty well, plus it addresses the temperature concern, but anything out there new and improved?
Rob
Dec 2, 1999
15,184
I have not had any issues with the MS butyl tape oozing. It can be an issue with some of the other brands out there.
Apr 8, 2010
1,606
If you put the butyl tape too thick it will ooze for a few weeks, maybe even a month after installation, but in my experience once everything is properly tightened down and stable, it does not not continue to ooze. I had it ooze for a while after redoing my stanchions and bimini frame base, but after about 2-4 weeks, depending on how thick it was on a given piece, it stopped and hasn't oozed at all since.
Even when it does ooze, it doesn't make any real mess and just takes a few minutes to clean up. I'm happy with my choice to use it, and will continue to do so in the future.
