Michael Conforti
I am looking for some advise on the best method of fixing a leak a have at the bottom of the companionway molding. This U shaped molding has several screws that hold it in place. The screws at the bottom seem to let water into the cabin on wind driven rainy days.I want to remove the entire molding and reset it in new chaulking. But I do not know if this is the best way to approach the problem. Also what type of chaulking do I use? If you have a Hunter especially a 28' have you have the same problem?This seems to be the only source of the water as the slats (both wood and plastic) do not appear to leak.
