I am installing a companionway cover for a Hunter 23.5, what adhesive is recommended for securing the snaps to the deck? Also any thought on aligning the cover with existing snaps?
I use a swim noodle as well. Does double duty as a .... swim noodleI use a swim noodle cut to the full length.
I use a swim noodle as well. Does double duty as a .... swim noodle![]()
Chris;
I was present when the original companionway cover was designed. You have no idea my involvement with this boat.
When installing snaps, use a small drill bit and the correct adhesive is 5200. There is a quick dry or one that takes 7 days to cure. As stated, take a large drill bit and in REVERSE, slowy bevel the gel coat away. If not the gel coat will crack and come off. Not sure what you would call it but there are bits for that that do not dig into the glass. ask at a hardware store.
You mention there are snaps there already. Could it be from a previous companionway cover? You can order your companionway cover from the forum site as they go to the very same mfg. that made them in the beginning. If you are going to match color with the green stripe, the color for the green is Persian Green.
Since you already have the snaps, I would order the cover without the snaps installed. Generally Ameriseam would send the covers to me with the snap hardware separate.
There were two covers, the standard companionway cover with the aluminum brace that was used and another that simply was covering the hatchway with the slider closed to keep rain out when gone. I found it best to have one set of snaps for both .
If you have any other questions, feel free to ask. the existing snaps, do you know which cover it was for.
