Responses
Hi Joe,  You can get the companionway boards (called 'pin boards') direct from the Hunter factory.  Call the 800 number listed on this site, and try the retail parts extension (I think his name is Mike Thomas).  They're about $60-$70, if I remember correctly, and you can get them finished or unfinished.  As for the bow light, it's a fairly common part- You should be able to find it in any marine store.  They're made by Aqua-Signal, series 25.  At my local West Marine, the replacement bulbs for the nav lights are right next to the replacement fixtures.  I think you need the 10-watt bulb (not the 5-watt) to meet the visibility requirements.Good luck!  If you need any more info, let us know...--Jon BastienH23 '2 Sheets to the Wind'H25 'Adagio'
