Only opportunities...
Shower sump is worthless, we don't use it.Freeze ice in large containers and use a squeeze pump to drain into the sink or install a y valve. Don' let it drain into the bilge.Had mold in the fuel tank, installed a port, drained, cleaned, never had a problem since (five years).Last year suddenly had fresh water in the bilge. Never figured out why. Used a large syringe with epoxy and filled the crack between the hull and toe rail. No leaks since.Banjo fittings on fuel lines leaked, replaced and no more problems.You WILL have a crack at the keel hull joint, and you WILL find rust on the keel. See the archives, but mostly don't worry about it. If the crack is too large, open it with a drimmel tool, fill with 5200, glass over, paint, and fogettaboutit.Relace the aluminum tanks, see Ronco.My fuel tank is in the aft locker. Holding tank was moved from the head locker to under the aft berth (switched with batteries). I may move it back to accomodate a larger, custom tank. We flush with two twelve ounce cups of fresh water to conserve tank space, and flush a small amount of vinegar each night to neutralize uric acid (see Peggy's book).Learn to sail the boat flat (see the archives).The best boat for the buck you will ever find.DRSs/v Synchrony1990 Hunter GEdmonds, WA (Puget Sound)Review and photos posted
