Commisioning my H 380
Commisioning a boat is primarily a dealer's task. I commissioned my H40 years ago and it took two of us two weeks to get the job done properly. There is a lot to do. Whatever the schedule, figure on doubling it in time.I have a 1999 H380 and it took over two months in Seattle to get it commissioned by the dealer. There really is two parts to this task, getting the boat ready for the seller and then getting the problems sorted out and fixed. The latter takes time and in some cases, you may not want to fix it according to Hunter or Dealer standards.On my boat we had a number of problems after commisioning. To list: windless not properly mounted, cockpit table support put on backwards, broken light switch in galley, faulty rudder, freezer/refrig not working well, through hull fitting not correctly placed, engine/shaft bolts not tightened or checked, wheel brake not working and a few others that I have forgotten. Another problem with commisioning a boat is that you have to decide is it a Hunter problem or a manufacturer problem. In our case Grunert (refrig) says the problem is Hunter and Hunter says the problem is Grunert. I finally got tired of Hunter, Grunert and the dealer and had SeaFreez come in and change the freezer and refrig. It now works to my satisfaction but interestingly enough not to SeaFreez. They want to do some more work this winter.My engine battery kept getting fried. No water in it after two weeks. It drove me crazy and I thought it might be the solar power switch. No, it was the Guest battery charger--it might have been wired wrong at the commisioning. Who's problem is that? Dealer, Guest, or Hunter. In our case, I yanked all the electrical stuff out, installed a StatPower battery charger, a combiner, an engine room regulator for the alternator, a Hart monitor and golf cart batteries. We are now pleased with our electrical system and can stay on the hook for 4 or 5 days without charging. Hunter and the Dealer refunded us for the Guest charger.It has taken us a year and a half to work out the kinks and problems of a new boat. We still have some problems to solve such as the Edson Wheel Brake, a royal pain. There are other little problems such as a galley faucet that we replaced only because I can't understand having a faucet where hot and cold turn in opposite directions. I installed a single level faucet that is much better.HOWEVER, and this is a big however, this Hunter 380 is an outstanding boat. Once you get everything working to your satisfaction, you will have one of the best boats on the water. If you will read in the "Sailor to Sailor forum" you will note that we just returned from Desolaton Sound in BC and had the trip of a lifetime. At the moment, I can't think of a way to improve the boat FOR US. Other people may have different needs, but this H380 is a great boat for this family. I hope you have a much fun with it as we do.Les BlackwellTrumpeter
