Don
Hello I was working on my boat and I realized that both the fore stay and samson post backing plates are starting to rot and should be replaced. 1. Since they are right next to each other could I make a backing plate for the two of them or would this do something negative in terms of spreading the strain out? 2. I got advice from someone saying I should use a thick plastic cutting board as a backing plate.... is this a good idea two quater inch plastic pieces with large washers or is that incredibly stupid?3. I'm assuming 4200 would be fine for sealing the pieces back on the deck and for sealing the plates.4. Should I be spackling with 4200... I broke a tube open so I decided to use it to fill in some cracks and chips in the gel coat... bad idea?Thanks I'm learning loads from everyone.Don
