Dan Jonas
I have a new 356 coming that will have two 4d batteries as seperate house banks. I will be adding a Balmar 100 amp alternator and a seperate Group 27 dedicated start battery. I am planning on using a Pathmaker combiner in the charging system. The boat will have a Heart Fredom 20 inverter/charger at 100 amps charging also. Several questions are coming up for me.1. What size Pathmaker? Seems like the 100 amp model might be just a little small.2. Is there any problem combining the two 4d's with the group 27? All will be the same type (AGM). I read somewhere that a better way to do this is with an Echo Charger. Any advice welcome.3. If I combine all three banks, will the smart regulator on the Balmar know not to overcharge the starter battery while trying to charge up a house battery? Or is the distribution of the power automatically in relation to the discharge of each individual battery?4. The Freedom Marine Inverter monitor will look at the two house banks. I suppose that I will need to add a Link 10 or something to monitor the status of the starter battery?I know these are somewhat technical questions. Hoping someone out there with a similar system will be able to help.Dan Jonas (S/V Feije)
