Not a question...just wanted to share my solution to a problem that others may have had.
I bought a dual-light masthead light that doubles as an all around anchor and also as a forward facing steaming light. Problem was the wiring diagram that came with the light uses a DPDT switch and a crossover wire to accomplish the 'both on' or 'forward only' modes, but my fuse panel was already labeled for these lights but had only SPST switches.
I considered just wiring each up on a switch and when I wanted an anchor light I would turn on both the Anchor and Steaming switch...but then I came up with the idea of inserting a diode between the anchor out and the steaming out poles of the switches and viola!
I used a 3A Barrel diode from radio shack ($1.50). Simple and effective.
