Com-Pac 16 general questions
shine
Sep 14, 2009
74
Macgregor 1985 25 ft. Macgregor swingkeel Mo
Does anyone know the pulling weight of these boats on the trailer? Which year models are best and why? Best and worst thing about them besides the price and small cabin?
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
And for my learning does the towing capacity of a vehicle include the weight of the vehicle?
For instance my jeep weighs about 4,000 lbs. Its towing capacity is around 6,000 lbs. So, a trailer and boat would have to be under 2,000 lbs. Is that right?
Feb 21, 2013
4,638
Towing capacity is the maximum weight a vehicle can tow. Whereas, Gross Combined Weight Rating {GCWR), which is the maximum weight of your vehicle with a trailer attached, as determined by the vehicle manufacturer, or combined weight means the weight of both the tow vehicle and the trailer together. It also includes any cargo or load placed in either vehicle. How to Measure Towing Capacity, GVWR, GCWR - Towing 101 (curtmfg.com),
4,638
Might consider obtaining the following weights at you local moving company truck scale:
1. tow vehicle with trailer/boat hooked up to obtain GCWR.
2. trailer/boat unhitched from the tow vehicle to obtain a total towed weight.
3. trailer/boat weight hitched to the tow vehicle off the scale to obtain net trailer/boat weight.
4. subract 3 from 2 to obtain tongue weight.
That is what I do to make confirm my trailer is not overloaded for the tow vehicle.
When I lived in Southold NY you could do this at the dump - ah, transfer station.
#3 Stumps me.
Feb 21, 2013
4,638
The method above is how I determined the pin weight (weight of the loaded trailer king pin on the tow vehicle bed hitch) of my fifth wheel trailer.
Jan 8, 2025
179
Compac 16 Pensacola, FL
While towing my just-purchased 16 home from Sarasota to Pensacola I didn't experience any trailer instability but I can lift the tongue easily with one hand and I'm no longer strong. If it doesn't require a complete reengineering of the beds and cutting/welding of the winch pedestal, I'm going to move the boat forward a couple of inches. I'd like at least 60-75 lbs tongue weight.
Jan 8, 2025
179
Good thought. It came with a spare. I've taken a close look. I won't need to change the bunks, just loosen the U-bolts and the cable, slide the pedistal forward an inch or two, tighten the U-bolts, and winch the bow tight. A spare mount may be within the playmoney budget after I get the running lights functioning.
