Bill
Purchased a 1975 Columbia T-23 a month ago. Got a nice little boat for a good price considering that it needs a refit and TLC. Plan to replace standing and running rigging, boom (most of the fittings are corroded and broken), plumbing (worn out), navigation lights (broken). The cabin is in good shape and it will be refinished and updated. I pulled the mast last week and removed the mast step where I found evidence of water leaking under the step and into the cabin top cavity under the deck. Does anyone know what is carrying the mast load to the cabin bulkhead posts? Is it a fiberglass, wood or metal beam? I don't want to start cutting into it unless I have to as the glass surfaces are in good shape. However I don't want to have the mast come down if the structure is compromised by the water intrusion. Also, the vinyl rub rail extrusion is battered and I want to replace it with a matching or similar one. Does anyone have a source for a replacement? This will be the second boat I have restored and I enjoy the work almost as much as sailing. I plan to use the boat to daysail and cruise the New England coast.
