Columbia 8.7 meter
A
Andrew Gealt
I have rencently purchased a 8.7. meter Columbia sailboat which comes to approx. 28'2". It has a full batten Mainsail and boom yet there is no mast or step. There is no running rigging with the boat. It appears to be quite different than the 28' Columbia sailboat that's the popular model nationwide. I was wondering if there were someone out there that has information or a similar model Columbia that could tell a little about the specifications of this boat. Most importantly, the mast size, rigging Jib, Jennys' the usual and customary questions a new boat owner might have. Thank you all for your continued support and friendly boater attitude. Andrew andrewgealt@yahoo.com
Nov 23, 2004
281
Columbia 8.7 Super wide body Deltaville(Richmond)VA
Columbia website
go to the website I've linked and click on Model information. Everything you ever wanted to know about your boat is there. There are links to blue prints, sail plans, laminating schedules, a registry with the names of other columbia owners. I own an 8.7, and there are several other active 8.7 owners at the Yahoo!Groups/Columbia Sailing Yachts e-mail list. There is a link At Columbia-yachts.com. Welcome to the Columbia family. Where is your boat? Larry Wilson Columbia 8.7 AllAboutMe Richmond,Va.
Nov 23, 2004
281
Columbia 8.7
GENERAL SPECIFICATIONS Model Name Columbia 8.7 Model Number 299 Length Overall 28'7" 8.7 m Designed Load Waterline Length 23'2" 7.1 m Beam 10'0" 3.0 m Draft 4'8" 1.4 m Displacement 8,500 lbs. 3,900 kg Ballast 3,500 lbs. 1,600 kg Rig Sloop Maximum Cabin Headroom 6'1" 1.85 m Sleeping Capacity 5 Vertical Clearance 41'3" 12.6 m Designer Alan Payne TECHNICAL SPECIFICATIONS Engine Standard Optional (per Pat Sturgeon) Manufacturer: Medalist Universal Motors Volvo Penta Volvo Penta Model: Atomic 2 MD6B MD 7 A Power: 10 H.P. @ 3000 RPM 10 H.P. @ 2400 RPM 13 H.P. Gear Model: MS Gear Ratio: 2.5:1 1.91:1 Batteries: 105 amp-hr (one standard, one optional) Propeller Shaft Material: Stainless Steel Diameter: 3/4 inch Length: 48.75 inches Propeller Material: Bronze Style: Solid 2 Blade Size: 15 in. Dia x 9 in. Pitch x 3/4 in. Bore Rotation: Right Hand (Left Hand with Diesel Option) Fuel Capacity: 20 Gallons Water Capacity Port: 30 Gallons Sail Area 100% Foretriangle 231 sq. ft. Main 185 sq. ft. Total (100%)Foretriangle 416 sq. ft. I= 37'5" J= 12'3" P= 32.25 (why they switched to fractions I don't know) E= 11'5"
